Sportsman hard start
Old 02-11-2007, 09:39 PM
RticKwad's Avatar
Runs Stealth!
Default Sportsman hard start
Yea, Stendori is our "On-line Mechanic"
Thank God he doesn't charge us,..LOL
R'
Old 02-11-2007, 10:16 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
what you should do is get a voltage tester to test the battery to make sure its got 12 to13 volt range. w/ the bike running it will be around 13 to 14 volts. if it isnt @ least that many volts while running chances are you have a charging issue. something to try any ways. charge the battery fully w/ a charger and then try it. if it starts right up then you know that there wasnt enough volts.
Old 02-11-2007, 10:44 PM
Bowz's Avatar
a load tester for your batt will also work. and also a little more infomative than a voltage test. 7o bucks at a local napa store. well worth the money, u can use it to test any batt. my .02
bowz
whitty
67
02-24-2021 02:52 PM
MikeyBoyesq
11-27-2020 02:44 PM
TegraQuad
1) Engine problems..
13
11-26-2017 01:40 PM
chinkapin
07-14-2016 06:58 AM
1000gade
05-27-2015 12:37 PM
Quick Reply: Sportsman hard start
