how much toulene(octane)?
Old Feb 2, 2007 | 05:15 PM
baseballx16x's Avatar
Default how much toulene?
if i have a 13:1 piston on my 05 trx450r, how much toulene would i need to mix with premium gas?
Old Feb 4, 2007 | 04:05 AM
TractorPacker's Avatar
Do you have a balloon?
Default how much toulene(octane)?
With 13:1 you will want to be at about 110 octane. I hope that helps.
Old Feb 4, 2007 | 12:40 PM
JRM's Avatar
JRM
toulene is a paint attitave, anything over 100 octane will keep your engine happy.
Old Feb 4, 2007 | 01:17 PM
Doctorturbo's Avatar
GOT BOOST!
Start at 10%. Dump it in, go out and read the plugs and look for signs of detonation. I would not go above 15% in any case. You should be fine at 10% at 13 to 1 and you will save a lot of $$'s over a year if you ride a lot. 13 to 1 is about the limit for making your own fuel. At least that is the way I see it.
Old Feb 4, 2007 | 04:20 PM
LittleBill's Avatar
doc i know a guy who says he is using lead substitute in his gas to bring his octane up, he is only running a 10:1 piston in a 300ex and he hasn't grenaded it yet. there any truth to this lead substitute?
Old Feb 4, 2007 | 05:05 PM
GOT BOOST!
There is all sorts of octane boosters on the market. Some good, some not so good. All different names and all different manufactures.
Unless you had a typo on the compression of your buddies piston he can run a 10 to 1 on regular gas. Sort of like I will sell you a bottle of elephant repellent, and you say but there is no elephants around here, and I say, see how good it works!!!
So to answer your question, yes some octane boosters work; some don't.
When I was messing with this stuff years ago, I would do like baseballx16x is going to do, make mine own with toulene. Worked good.
Old Feb 5, 2007 | 05:20 PM
wen u mean 10% do u mean 10% of the fuel tank?
Old Feb 6, 2007 | 12:31 AM
GOT BOOST!
10% is 10%. It does not matter if you have 5 gallons or 500 gallons.
Take 10 gallons and put a gallon of tollie in and call it good. Or take a 5er of gas and put a half a gallon of tollie in it. Or take 2 1/2 gallons of gas and put a quart of tollie in it................................................ ....and on and on and on it goes.....................................
Old Feb 6, 2007 | 05:03 AM
Waterplay's Avatar
You may wish to try Max Lead 2000? Very good stuff as long as you don't have a catalytic converter. LOL
here is a link http://www.maxlead2000.com/
Polaris-400
Aug 19, 2015 02:20 AM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
ranvette
Jun 10, 2015 09:57 PM
Tree Farmer
May 6, 2000 03:36 AM
