250r parts interchangable with 400ex
Old Dec 15, 2000 | 04:17 PM
ytztriz's Avatar
Will a 2000 ex swingarm fit on a 86 trx also a thumb throttle would i have to get a 400 cable or 250r cable also the front shocks will they hook up with the 250 a arms
Old Dec 15, 2000 | 05:05 PM
retro's Avatar
I doubt the swingarm would fit, the thumb throttle is different! A 4-stroke throttle has to open a valve while a 2-stroke throttle has to raise a slide. The A-arms should fit and might give you a little more ground clearance.
ERIC
Old Dec 15, 2000 | 05:27 PM
400exalltheway's Avatar
swingarm is a diffenet no. i tried it. throttle no, and the shocks will fit.
Old Dec 15, 2000 | 08:36 PM
Witz's Avatar
Actually, the 400EX throttle will work, with a little modification. The 400EX throttle is the same as the 250X/300EX throttle and uses a straight arm rather than the cam that the 250R throttle uses. I switched to a 250X throttle for my 250R and throttle pull is much easier. The problem is getting enough throw to open the carb all the way. A little grinding is required on the inside of the EX throttle to get full throttle on an R. I also machined my own extension piece where the cable threads into the housing, to essentially lengthen the housing. It takes a little work, but it's worth it for throttle pull.
Old Dec 15, 2000 | 08:50 PM
tprender's Avatar
You can put a 250r swingarm on a 400ex, but you must have everything. We just did thing on a friend's 400. He took the whole rear end from his 250r. He did use the 400 rear shock. The quad rides very good and jumps and lands with no problems.
Old Dec 15, 2000 | 09:35 PM
yeah you can put a 250r swingarm on a 400ex but you can't put a 400ex swingarm on a 250r.
Old Dec 15, 2000 | 10:33 PM
mx250r91's Avatar
Will 400ex tie rod ends work on my R?
And also will 400ex bearings fit 88 front hubs?
Old Dec 16, 2000 | 08:57 AM
tie rod ends will, but i'm not sure abot the bearings
Old Dec 18, 2000 | 12:17 AM
Fitz's Avatar
400ex a-arms on a 250R ?
Old Dec 18, 2000 | 08:57 PM
tprender's Avatar
Tie rods and ends with inter change, but the quality of the 400 ones are not as good as the 250 r ones. There is a big price difference between the two and it can be seen in the quality of them.
