Breeze sparks too much?
Old Feb 4, 2007 | 06:55 PM
nastyDub's Avatar
Default Breeze sparks too much?
89 breeze sparks on every stroke maybe even more. Revs fine in neutral but lacks power in drive. Any help would be great.
Old Feb 4, 2007 | 11:20 PM
Doctorturbo's Avatar
GOT BOOST!
A lot of engines have a wasted spark. Is the Breeze one of them? I have no idea and it does not really matter. They all run fine.
You need to check several things.
#1. Do a compression check.
#2. Check out the clutch. If it lacks power one of the sheves might not be opening/closing up.
If it seems to run good my vote would be a clutch problem.
Old Feb 5, 2007 | 11:35 AM
nastyDub's Avatar
I should give more details. The bike fires up right away. The engine revs in neutral but not smooth. In drive it will move but starts to bog out at half throttle. We had it out one night and it worked perfect. The next day we changed fluids, new air filter, and cleaned carb. The air boot between the carb and the cylinder is in rough shape (new one coming). The carb was leaking gas (dripping) none stop, therefore we cleaned it. Gas leak has stopped but now the running issues. We've checked the carb over and over but nothing seems to be out of whack. We will check compression. What psi?
Old Feb 6, 2007 | 11:42 PM
GOT BOOST!
Well, I don't think I can diagnosis this over the net. If I have to guess, and I do mean guess, I would say you have a carb problem. Sorry I can't be more help
Old Feb 7, 2007 | 06:09 PM
nastyDub's Avatar
Thanks anyway![img]i/expressions/face-icon-small-smile.gif[/img]
fordfaithful21
Dec 7, 2015 05:52 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
