ranger oil
Old Feb 5, 2007 | 07:25 AM
retry's Avatar
Default ranger oil
help. ranger 500 oil tahk overflowing. what is the cause? what is the fix? thanks in advance.
Old Feb 5, 2007 | 07:53 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default ranger oil
im not too sure about the ranger set up but assuming it has a seprate oil tank like the sportsman 500 right. does it have too much oil in it. how is it overflowing w/ the cap screwed in.
Old Feb 5, 2007 | 11:06 AM
sheepdogMSP8117's Avatar
Default ranger oil
Overflowing into the airbox? Check the oil level in accordance with what the manual says. If it's been overfilled, drain the excess. If the level is correct, make sure you warm up the engine sufficiently before getting on it too hard, especially in these cold temps.
Let us know what you find out.
Old Feb 5, 2007 | 11:08 AM
retry's Avatar
Default ranger oil
when cap is removed oil over flows. it was avery cold mourning an i saw some oil on the ground after starting,so i checked the oil tank and oil poured out. im thinking condensation froze. thank you for your reply.
Old Feb 5, 2007 | 11:24 AM
Kerbbirds's Avatar
Default ranger oil
Get it in and warm it up, I've heard of condensation freezing oil lines and ruining motors, I wouldnt run it till I figured it out , get it in somewhere and warm it up, check for milky oil,"water in oil. Let us know what you find.
Old Mar 5, 2007 | 08:31 PM
retry's Avatar
Default ranger oil
kerbberbs: about ranger oil,. finaly warmed it up and changed oil. the oil was not milky, but a cup of clear water drained out of the bottom of the tank. everything seems normal now. thanks.
Old Mar 5, 2007 | 08:36 PM
retry's Avatar
Default ranger oil
sorry, i ment kerbbirds.
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
WilliamBos
Sep 22, 2015 04:07 PM
greg74
Sep 10, 2015 07:58 AM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
