04 400 auto dies when you get it in water
Old Feb 5, 2007 | 11:10 AM
WingNutTx's Avatar
Default 04 400 auto dies when you get it in water
We have a 04 400 that over the weekend it just started dying when you got it in water that went over the floorboards. After you let it sit about 15 min or so and prime the carb about 5 times hold the throttle wide open it will finally start. Any ideas???
Old Feb 5, 2007 | 11:16 AM
Catterman's Avatar
Got Milk!
Blaming Guns For Crime Is Like Blaming a Spoon for Rosie O'Donnell being Fat!
Check your carb vent lines, and put some Sea Foam in your gas tank. YOu might have water in there. When you hit the water was there a lot of steam that came up?
Old Feb 5, 2007 | 11:18 AM
WingNutTx's Avatar
Not to much. The air box was dry. It also sometimes when cranking it would blow white smoke.
Old Feb 5, 2007 | 11:59 AM
Catterman's Avatar
Got Milk!
Have you ever adjusted your carb? Sounds like soemthign might be messed up in there.
Old Feb 5, 2007 | 02:08 PM
sevenmag's Avatar
I know on my 06 400 auto the carb vent lines were on the skid plate. Had the same problem; it would die in the water. Ran them up along the hndlebars and never had that problem again.
Old Feb 5, 2007 | 02:20 PM
hondabuster's Avatar
You could try putting dielectric grease on the outside of the spark plug and in the spark plug cap, to prevent shorting out the spark in wet conditions.
Old Feb 5, 2007 | 11:03 PM
Chumley's Avatar
Don't drive it in the water over the floorboards?
Can't believe I was the first to say it.
Old Feb 6, 2007 | 01:56 PM
kickass210's Avatar
water is getting in on the stator. or the ignition sytem. u need to seal that area. its probaly hiting a gasket in one of the seals.
Old Feb 11, 2007 | 11:42 AM
WingNutTx's Avatar
Thanks for the help. We moved the vent tube up by the handlebars and then tested it after we had it up the the tank in water. It did not always act up then after moving we could go in any depth of water and it was fine. Thanks again for the help.
gorylewis
27
Oct 4, 2015 05:22 PM
SDR-II
Sep 29, 2015 01:06 AM
Knackknack
Aug 19, 2015 07:45 AM
house1
Aug 9, 2015 10:49 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
