scrambler 400
Old Feb 6, 2007 | 09:22 PM
tmzg29's Avatar
Default scrambler 400
What is the normal compression for a scrambler 400. I don't know what the reading should be. I ran a compression check and it is 120. My scrambler is a 1999 and it is yet to have a new pistion and rings. All 2 strokes that I have rebuilt in the past, the compression was between 110 and 135 after a rebuild. I am guessing that 120 is good but just thought I would ask.
Old Feb 6, 2007 | 10:44 PM
RDZ350's Avatar
I have heard numerous times about how a stock piston will break.
People that build these 400's will tell you to get rid of the stock piston and replace it with a wiseco.
Old Feb 7, 2007 | 12:08 AM
scrammersam's Avatar
good compression but id pull that stock piston and throw the wiesco in for what its worth
Old Feb 9, 2007 | 10:47 PM
tmzg29's Avatar
I guess I need to put a new pistion and rigs in it. Just don't understand why if I got good readings.
Old Feb 9, 2007 | 11:11 PM
2manytoys's Avatar
The reason is because the weak point of these pistons is the skirt. If the skirt breaks you will need a motor. Even if you have good compression and its a 99 it would only cost about $80 for a wiseco then you dont have to ever worry about the skirt breaking.
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
