WHICH HONDA
Old Feb 7, 2007 | 09:24 AM
erno's Avatar
Default WHICH HONDA
Currently own a 450 ES which I have used extensively on the farm since brand new in 1999
Have had no real trouble has given good service,rounding up,chasing,trekking,hauling,towing,speeding the lot.
Thinking of replacing it and would like advice on whether I should buy a new TRX 500 or a TRX 680
The machine will be used primarily on the farm as a work horse
Old Feb 7, 2007 | 10:24 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default WHICH HONDA
I think for a work quad you are going to want to stick with a solid axle machine, which the Rincon isn't. Plus the Rincon's automatic transmission doesn't have a reputation for having much low end grunt. Even Honda calls it an "SUV", so I don't even think they are trying to market it a "work" quad.
The Rubicon automatic is also a "TRX 500", so it isn't really clear whether you are considering it as well????
You have had great luck with the previous Foreman that has a nice simple manual transmission, so why mess with perfection??? I say stick with the Foreman 500!
Old Feb 7, 2007 | 10:47 AM
erno's Avatar
Default WHICH HONDA
Thanks for trhe advice. Yes it is a Foreman 500TRX 500 AND NO CAN ONLY AFFORD ONE UNFORTUNATELY!!
Old Feb 7, 2007 | 11:15 AM
mykool61679's Avatar
Default WHICH HONDA
foreman, most definatly!
Old Feb 7, 2007 | 11:36 AM
Red Rider
Default WHICH HONDA
There are several things about the new Foreman that you will like. It has selectable 2wd/4wd, unlike the old Foreman that is full time 4wd. And, the old Foreman has a "limited slip" differential, where the new Foreman has a much better "torque sensing" differential.
Old Feb 7, 2007 | 01:52 PM
oldturtle's Avatar
Default WHICH HONDA
The only competition for the Foreman 500 FM would be the new Rancher 420 EFI FM. I think that last year when the Ranchers were 326cc +/- then the actual 475cc Foreman was substantially more powerfull and a better pure work ute. Now with the greatly improved Rancher 420 the choice is much tougher. So for the light end of duties the Rancher would excel while at the heavier tow/haul end the Foreman would excel. But either one could easily do it all.
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
rgjackson
Sep 17, 2015 11:21 AM
wendal
Sep 15, 2015 01:50 PM
Jason Campbell
Sep 7, 2015 02:25 PM
