fmf magamax on scrambler
Old Feb 8, 2007 | 01:25 AM
gr8one's Avatar
Default fmf magamax on scrambler
so i got the magamax with no instrutions just hardwear so i put it on does anyone have pics of scramblers with this pipe on it and also i have no rejetted it should i and also how many disc should i run and do i put the t looking thing in there? i am looking for bottom end and no so much sound. Sorry for the noob questions but i am sure somone knows what to do
Old Feb 10, 2007 | 10:03 PM
gr8one's Avatar
so i took it out today and bottom end feels good but i lost top end and its still running very rich it almost blackend the tip in 2 hrs. i tried running without the top of the air box on but it would bog any help ideas????????
Old Feb 10, 2007 | 10:18 PM
bongload's Avatar
I had one on my scramy 500..I ran it with all the plates in it and the baffle/ spark arrestor out.stock jetting. It ran good.
Old Feb 10, 2007 | 10:41 PM
Baconbits's Avatar
Yea man, your supposed to leave it with stock jetting IMO is just better, no hassle. The more discs, the less sound, the less discs the more sound...Heres a pic on my moms 250ex...Theres also some in my photos...
Old Feb 11, 2007 | 08:43 AM
1bad85gt's Avatar
I thought that you had to rejet for any aftermarket exhaust? Slip on or full.....? I see where people have to rejet just for putting a K&N air filter on, so I would think that exhaust would make more of a lean/rich condition than an air filter?
Old Feb 11, 2007 | 09:33 AM
ftwflh's Avatar
Polaris jets rich from the factory.I havent had to rejet any on my 4strokes for just a Airfilter and pipe change.Now the 2strokes will need rejetted after a pipe but not ussually after just an airfilter unles you mod the airbox.
Old Feb 11, 2007 | 09:56 AM
1bad85gt's Avatar
Just sent you a PM ftwflh.
Old Feb 12, 2007 | 02:13 AM
gr8one's Avatar
so what do i do it sounds like i am running rich if i were to add more disk will it lean it out a lil??? and can i have more in for on the baffle and spark arrestor so i can see what to take out.
Old Feb 12, 2007 | 08:00 AM
ftwflh's Avatar
Do plug check first to be sure it is rich.Then you can add or remove discs until you get it right or you can do the carb.I would try the discs first.
Old Feb 13, 2007 | 12:16 AM
gr8one's Avatar
thanks
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
