How do you keep from fogging up
Old Feb 9, 2007 | 08:14 AM
JDMAN60's Avatar
Default How do you keep from fogging up
I have a street bike helmet that I wear when I ride my quad in the winter for face protection. The problem is when I wear it the lens fogs up as soon as I exhale then I have to open it up to be able to see. I was wondering what you all wear when you ride in the winter? Thanks *****
Old Feb 9, 2007 | 11:07 AM
MnFriesen's Avatar
I normally wear just my normal helmet and then sunglasses...us minnesotans are tough ehh?
Old Feb 9, 2007 | 11:20 AM
xFreebirdx's Avatar
Administrator¿
Resident Killer!
"A little nonsense now and then, is relished by the wisest men". Willy Wonka: 1971
Cigars! Earth ne'eer did breed such a jovial weed.
A Tiger Doesn't Lose Sleep Over Opinions of Sheep
Veteran: Army
Loved
Community Favorite
If you don't have a duel shield it will be impossible, or a air flow system that flows air across the shield on the inside. [img]i/expressions/face-icon-small-sad.gif[/img]
Old Feb 9, 2007 | 12:00 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Yes that is right...You need the winter type shield that has a space between them!!! They have a pocket of air between them that keeps the outer one cold and the inner one warm when you breathe
Also a breath diflector will help even with the double shield.
Only other option is to stop breathing when you put your helmet on!!!!!!!!....Caper.......
Old Feb 9, 2007 | 07:45 PM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
I use a street helmet with no fogging problems. I usually will run with it cracked just a tiny bit - an opening so small that you can barely see it. This is enough airflow to keep if from fogging. A breath deflector would also help, but mine works OK without one.
Jaybee
Old Feb 10, 2007 | 12:11 PM
mykool61679's Avatar
a full face ski-mask and a pair of shades!![img]i/expressions/face-icon-small-cool.gif[/img]
Old Feb 10, 2007 | 03:07 PM
DVXDUDE's Avatar
I dont know if this would work with helmets in thw winter ...dont really see why it wouldnt but when i'm paintballing i use this anti-fog wax stuff that you put on the lense then wipe it with a rag and it stops it from fogging up. just called anti-fog stick or something
Old Feb 10, 2007 | 08:16 PM
bullseye9's Avatar
rain ex anti fog works or a car wax (carnuba). Instead of fogging the moisture will collect and run off. It also works great on a bathroom mirror to keep it from steaming up....
Old Feb 11, 2007 | 08:31 AM
JDMAN60's Avatar
Thanks to all for your suggestions I will try them out today.
Old Feb 11, 2007 | 10:06 PM
XxBamBam2xX's Avatar
yea i would just crack it a little bit and once you get going it should be good
