Can one Modify the Standard Exhaust
Old Feb 16, 2007 | 06:57 AM
Rich1's Avatar
Default New DS650 Owner
Hi There,
Just bought me new DS 650, love it and sure lot diffrent from my Trailblazer.
Is there any way that some can tell me if I get this thing to sound a bit better without
changing the exhause or spending any $$.
I will do that later but for now is there any mods that I can do withou damanging the engine.
Thanks
Richard Strydom
South Africa
Old Feb 16, 2007 | 09:15 AM
learnem's Avatar
Default Can one Modify the Standard Exhaust
mrhp makes an endcap that cost about 70 bucks that you can swap out. cool thing is too, it makes some of the best horsepower among the aftermarket exhausts, too
Old Feb 16, 2007 | 01:51 PM
ben362's Avatar
Here is some good info.
Exhaust info
Old Feb 16, 2007 | 01:59 PM
FatHolly's Avatar
How good are your fab skills.... you could cut out the center section of the stock end cap.... it does the same thing as the Mr HP end cap... you will need to rejet though.
Old Feb 16, 2007 | 11:08 PM
jiminok's Avatar
Check my pics...I've got a modified endcap that cost me $20 at a local muff shop. It ain't very blingy but it does what you want.
Old Feb 16, 2007 | 11:14 PM
DragonDJ11's Avatar
Originally posted by: Rich1
Hi There,
Thanks
Richard Strydom
South Africa
Yes, take the end cap off, and cut the screen out, and open the two exhaust ports out. That will do you wonders, and cost nothing. Can be done with a standard metal saw blade...
Old Feb 17, 2007 | 05:16 PM
fourlix's Avatar
CHeck my pix. Mine has been dyno tested for about 4 additional hp, it sounds a lot better, and just a little louder. It makes the stock exhaust into a reverse cone megaphone and contains a swirl type spark arrestor.
Old Feb 19, 2007 | 03:52 AM
Rich1's Avatar
Old Feb 19, 2007 | 03:54 AM
Rich1's Avatar
Thanks... sounds good.
Do I then still need to take in for rejet... or just by opening that ports it will be ok
Old Feb 19, 2007 | 10:27 AM
fourlix's Avatar
As soon as you do anything to the exhaust on a DS, you start hitting the rev limiter. SO you will need to change that. Check your plug, it will tell you if you need to rejet...
Pehter
Oct 3, 2024 11:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
