Weird gas leak
Old Feb 21, 2007 | 02:25 PM
Cammer's Avatar
Default Weird gas leak
Heys guys I noticed some gas residue on the right side engine case. I have followerd it up and it appears to either be coming from the tank or the 2 carb. vent hoses that tuck under the tank. It isn't dripping on the floor but it has made a mess on top of the carb and under the tank. Any ideas? Before I take it all apart I was hoping for suggestions because I can't really see where it is leaking from.
Thanx
Cam
Old Feb 21, 2007 | 03:16 PM
BioWare's Avatar
Toxic Ryder
If i'm not mistake, I think there is a over flow hose that runs down the left side on the back of the raditor, maybe it came disconnected on the top of it.
Just my two cents..
Old Feb 21, 2007 | 06:11 PM
Cammer's Avatar
Bio,
Thanx I will check that tomorrow. Any idea where on the tank it connects?
Cam
Old Feb 21, 2007 | 06:26 PM
BioWare's Avatar
Toxic Ryder
I have now idea where is connects under the tank.( on top i think). But i'm pretty sure if you follow the tube you will find it. Again this is just a guess on where it is leaking. Does it only leak when you ride. Or the carb is leaking out..
Just my 2 cents
Old Feb 21, 2007 | 06:29 PM
Cammer's Avatar
Only when I ride. There doesn't appear too be any fresh gas as it has been sitting for a few weeks
Old Feb 21, 2007 | 06:35 PM
BioWare's Avatar
Toxic Ryder
It might be just splashing out that hole where that hose connects under the tank then. I would start their. I believe it is a vent hose for the gas tank. Bombardier DS650 does not put a vent hole on the gas cap. this why the hose is their.
Old Feb 22, 2007 | 11:03 PM
cynick's Avatar
When your bike is sitting, is the gas off? Mine had a strange leak when I would turn my gas on, turned out to be my floats were set too high from when I rejetted.
Old Feb 23, 2007 | 08:50 AM
KaylasDaddy's Avatar
Has been riding one thing or another since I was 11 years old.(31 years).
if it is the tank vent, pull the tank cover & you will see it on top. the vent hose is about 3 ft long & wraps around the tank. be sure not to pinch it or you will vapor lock. i vented the stock cap to be sure it would vent .
Old Feb 23, 2007 | 03:10 PM
Cammer's Avatar
After further inspection it appears that it is oil not gas. It looks like it is coming from the crankcase overflow line that ends under the gas tank. I am thinking that I put too much oil in at the last oill change, correct?
Old Feb 25, 2007 | 11:52 PM
cynick's Avatar
Is the return line on the valve cover hard? If it is that is probably your leak.
