Foreman rear brakes
I just replaced the rear brakes on my 2004 honda foreman and now the brakes squeak alot at low speeds. If I loosen them the squeaking goes away but so do the brakes . Is there anything I can do to fix this or do I have to learn to live with the noise?
Common cause for brake squeal after installing new lining's? Not properly preping drum's or rotor's on automobile's as well as atv's, the drum's or roto's need to be ruffed up or resurfaced to remove the glazing that build's up on them when the old lining wear out ! On atv's you can use emerory cloth to ruff up drum or rotor , but in some case's you may need to find a dealer or machine shop to do the resurfacing for you to get them like they were when new ! Hope this help's...........williebee
SixSpeed5
8
Aug 2, 2015 05:38 PM
Jul 22, 2015 05:00 AM
