250sx carb ???
Old Mar 11, 2007 | 09:20 PM
wrestleu's Avatar
Default 250sx carb ???
Just pulled the carb off the SX and cleaned it. Now the gas just runs unobstructed out the bottom overflow of the carb. I assume this is a stuck float, however the float seems to be working smoothly, however the choke is stuck in the open position and won't budge. Could it be from the choke? I'm at my wits end, I'm getting tired of pulling the dang thing out and taking it apart all the time. I just want to get this fixed. Any suggestions on what to look for? Is it time to order a rebuild kit, and do it the all up?
Old Mar 12, 2007 | 04:06 PM
popup's Avatar
i just had the same problem.the screw at the bottom of the carb was corroded at the tip i had a extra carb and changed it and that fixed it. the drain screw.
Old Mar 12, 2007 | 04:50 PM
wrestleu's Avatar
Well, this is definitely coming from the overflow outlet tube. I assume it has to be a stuck float. I've never really run into a stuck float before, so I'm not sure how to remedy it.
Old Mar 13, 2007 | 11:31 PM
ssman828's Avatar
if i were you i would check the needle valve if it has one which i think it does-the ends mushroom out and allow gas to squeeze by it-very inexpensive and you can def do it yourself-good luck
Old Mar 14, 2007 | 02:33 PM
popup's Avatar
"drain screw" if the tip is corroded the gas leaks out the drain hole. the screw should have a rounded end at the tip to stop the gas.the screws purpose is to drain the gas out of the carb out the bottom drain hole.it took me a long time to find the problem on my carb it was doing the same thing.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
