outlander won't start in gear
Old Mar 11, 2007 | 09:57 PM
droil5's Avatar
Default outlander won't start in gear
anyone ? could really use some hep here.[img]i/expressions/face-icon-small-frown.gif[/img]
Old Mar 12, 2007 | 09:06 AM
BBR650's Avatar
Is always changing bikes.
try neutral or park........saftey first! maybe pull in the brake handle....
Old Mar 12, 2007 | 03:04 PM
kas379's Avatar
My Renegade occassionally has the same problem. I notice when it wont start in gear with the brake on, the brake light doesnt work either. Other times it works, go figure. I figure there is something not adjusted, or the mechanism to over ride it is faulty. Let me know what you find out. Does it ever work, or is it an on and off problem. For some reason, i think mine does it more so if it's really cold, maybe something is freezing that gets actuated when the brake is depressed. In any event let me know what you find out.
Old Mar 12, 2007 | 07:18 PM
JimJa's Avatar
The start in gear feature is connected to the brake light circuit. If your brake light is not on and is not burnt out, the bike will not engage the starter. Look there first. Sometimes the brake light pressure switch is faulty and requires excessive pressure to make the brake light function even though there is plenty of braking force to stop the bike. Try squeezing the brake until the light is on, then try engaging the starter. Obviously, if the starter will still not engage then the problem is elsewhere.
Old Mar 13, 2007 | 01:25 AM
kas379's Avatar
Mine works some of the time and other times it doesn't but the brake light doesnt work either when it wont start so there has to be something wrong with what activates the brake light, because it also allows the motor to turn over in gear. Its not consistent though on my Renegade.
Old Mar 13, 2007 | 11:50 AM
droil5's Avatar
sounds like the pressure switch as well. on the outlander it is located behind the left front wheel.
two wires on it and it is threaded into the master cyl. easy fix on mine switch is available at napa
echlin #sl 134
Old Mar 13, 2007 | 04:39 PM
blowedpony's Avatar
Ha Ha, shows how much I know, my 800 has NEVER started in gear, only in park or neutral. I thought it was like that from the factory!
Old Mar 14, 2007 | 01:39 PM
kas379's Avatar
I know my Renegade is supposed to as long as you have the brake on, dont know about the Outlander but i'm assuing its the same.
Old Mar 15, 2007 | 01:31 AM
kawiyowee's Avatar
The Renegade is the same as the Outy for starting in gear.
kas, go back to the tech tip, you know the one, more info there just tonight.
Old Apr 10, 2007 | 04:23 PM
kas379's Avatar
Hey by the way, for anyone still interested in this thread, I havent had a problem with mine since it's gotten a little warmer. I asked a tech at the dealership and he suggested the extreme cold temps may have caused the fluid in the master cylinder to thickening up and thus preventing it from actuating the override feature. Does anyone know if that can be adjusted so the brake light will come on sooner and with less brake pressure applied?
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
Dabears1983
Jun 16, 2015 12:17 PM
1000gade
May 27, 2015 12:37 PM
