Freezing hubs
Old Dec 19, 2000 | 04:07 PM
drlaney's Avatar
Fellow ATV owners,
Anyone have tips on the best way to keep your front wheel hubs from freezing up in cold weather. Had this happen to me for the first time this past weekend here in SE Texas when the temperature dropped to 22 degrees. I must admit that I let a year pass since I took the hubs off and performed preventative maintenance on the front brake assembly. Did this yesterday and really did not find them is very bad shape. Cleaned and greased everything well and will see if it helps.
Thanks.
Old Dec 24, 2000 | 12:48 PM
ecorman1's Avatar
Yes, we deal with this problem often in the north. It's a good idea to use water proof grease on all the surfaces of moving parts such as drum seals, bearings, mating surfaces and shafts. I don't know how the heck you're gonna keep all the water out but regular servicing and constant use is a plus. And be happy you have a quad to work on... :0)
Chuck, Suzuki KQ 300, GPS & lunch...
blueandy88
Sep 7, 2020 03:11 PM
jdunne01
Oct 4, 2015 10:29 AM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
snowolson
Aug 31, 2015 03:51 PM
blueandy88
Aug 30, 2015 08:26 PM
