I need TRX 90 Engine...help?
So i'm working on a project, small bike.
I have ridden a 2003 Trx 90 few times...small engine, quiet, auto clutch, and its honda.
trx90 is 250lbs + rider (another 150)
And it moves pretty damn good, and fast.
So that is why i want to get this engine.
Where is the best/cheapest place to get trx90 engine?
There is a local honda dealer just down the block, first time i went there and i told them i need trx90 engine...they told me "too bad, we don't sell engine, you gotta bring and rebuild what you have"
Next day i call and talk to the manager, he said "Dude i can get you ANYTHING you want," he was pretty cool. As I remember he said it will cost something like $1400...not cheap.
I been looking on ebay forever...can't find trx90 engine.
Any help?
Any help?
Originally posted by: crazy1291
why would you want a 90 though to start a project? are you going to put it in a dirtbike? that is the only way i can see a 90 being able to hit 50-60mph.
The reason i want this engine is is because it comes with 4 speed tranny, it will last for a while, and no where loud as 2 stroke.
How fast does trx90 go? about 35mph? If it pushes 400lbs to that speed, then i'm guessing it would push 200lbs to at least 50-55mph, which is more then enough.
Why dont you just buy a Yamaha TT-R90 dirtbike with 3 or 4 speed autoclutch? it produces excellent power for its displacement, the tt-r90 produces more power than the Kawazuki drz/klx110. I've driven both.
You think ttR90 engine would have about equal power as trx90?
definately, the tt-r90 is a very good engine and will probably have much more power than the trx90,
Those are the specs for a TT-r90, but i doubt that the honda has that high numbers,
Power: 5.49 HP (4.0 kW)) @ 7000 RPM
Torque: 6.10 Nm (6 nm or 4.5 ft.lbs)
You said the trx90 will do 35mph? i doubt that, that is as fast as a Polaris phoenix 200, I think a stock trx90 won't exceed 20-25mph.
about 55-60mph
about 55-60mph
Then i guess it has about the same power as trx90 if not more...but just different gearing and sprockets since trx90 weighs a ton
You can get a 110cc engine for it (well, it fits the ATC70 anyway) for under $400.
(Might be a bit over 400 by the time you throw in a carb and any other goodies)
http://www.dratv.com/11au4elbo.html
