messed up really bad on 300ex mo
Old Mar 14, 2007 | 07:48 PM
exrider91's Avatar
Default messed up really bad on 300ex mo
a few weeks ago i took out my motor to fix a crack and change my cluch springs.now today i got the motor back in everthing hooked up.now i remember leaving the engine in reverse and now i can shift in all the gears and cant move the part that connects the lever to the engine.tomoro im taking off off the cluch cover to see if something moved so the sencers are not connected anymore.
Old Mar 14, 2007 | 08:01 PM
TractorPacker's Avatar
Do you have a balloon?
There is a cable that comes of of the clutch perch, that goes to right rear, lower corner of the engine. It hooks into a small arm, that pivots abot 90 degrees. That arm locks out reverse. Look to see that the cable throws the arm all the way. Push in the red button, pull in the clutch, and then see if the little arm will go further. It will take some sort of wrench and probably a 3rd hand.
Old Mar 14, 2007 | 08:08 PM
exrider91's Avatar
i know about that i tryed pushing it with a crow bar and it didnt move.in the cluch cover the lever is connected to a spring and i think when i took off the cover the spring moved it and its being held by the metal plate it sould be on.i was thinking because i can shift thought the gears when the engine is in reverse i messed something up.
Old Mar 15, 2007 | 12:00 AM
OK, I can't help on that. I was trying to save you some labor, but you are a step ahead.
Old Mar 15, 2007 | 03:30 PM
exrider91's Avatar
thats ok thanks anyway what i should be asking is im i doing any damage to the trans by shifting to first when the trans was in reverse.
Old Mar 15, 2007 | 10:53 PM
Bowz's Avatar
i always do....no probs here:S
bowz
Old Mar 16, 2007 | 05:03 PM
exrider91's Avatar
ok it scared me because i was told that it can mess up the gear indactior and you would never get out of reverse again just five revese speeds.
Old Mar 16, 2007 | 05:18 PM
Bowz's Avatar
well, i do alot of things i shouldn't, i'm not garenteein that it woudltn happen, but i've seen more than mine do just what i do. and not one prob
bowz
Old Mar 28, 2007 | 10:58 PM
exrider91's Avatar
just took apart the casing again still the same problem. to list them my gear indacator dosnt work,no reverse and have to hold the clucth to start the engine and messing with reverse i broke the lever.im saleing the quad should i try to get it fixed or just get raid of it asis.it runs fine, doesnt leak oil,just dosnt have reverese.asis how much do you think i can get for it all the mods on it are on my page.
salixair
Nov 3, 2015 08:25 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
Wiley wolf
Sep 7, 2015 08:32 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
