? on 2007 400 trxex
Old Mar 16, 2007 | 08:50 AM
Tbone9's Avatar
Default ? on 2007 400 trxex
Hi I just baught a 2007 honda 400 trxex and when I start it for warming it up it has a ticking noise.then when its warm the ticking noise goes away after its warmed up.wondering if its normal or not.also should I be able to pop a wheelee in second gear without popping the clutch.Im 6'1 235 pounds. Im just curios.
Old Mar 16, 2007 | 08:58 AM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
There is a humming noise with the EX's, is that what you are refering too?
Yes it should bring the front end up easy in 2nd.
Old Mar 16, 2007 | 08:59 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
The ticking might be a tight valve, that loosens up after it warms up???
Some break-in info: http://www.mototuneusa.com/break_in_secrets.htm
Change your oil and oil filter early on, like at 1 or 2 hours to get any metal shavings out of the engine. Run a dino oil like Honda GN4 during break-in (~10 hours), but after that I suggest you switch to a synthetic oil.....my favorite is Maxima Extra. Some good basic oil info, you might find helpfull: http://www.thumperfaq.com/oil.htm
The 20 hour valve adjustment is important as well!
Old Mar 16, 2007 | 09:27 AM
Tbone9's Avatar
yes its like a humming or ticking noise.and also I have to pop the clutch to pull a wheellee second.first gear I dont.
Old Mar 16, 2007 | 10:39 AM
bombrider04's Avatar
Welcome to the forums...Don't pop the clutch you shoudln't have to at all if I could being at 150 pds pop a wheelie on an Ozark 250 which is a ute you should be able to pull a wheelie on a 400ex...The best way to go about doing so is when you hit the gas pull your weight back at the same time, but make sure you don't fall off the back and you should be fine...The noise is normal like the others said.
Old Mar 16, 2007 | 10:45 AM
Tbone9's Avatar
Thanks for replying I will try that.but right now its snowing hard so I wont have much traction.yes this forum is awsome.I look forward to useing it in the next couple of years.
Old Mar 16, 2007 | 01:13 PM
Red Rider
You're getting snow, and here it's in the 90's...........
Old Mar 16, 2007 | 03:16 PM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
with the majority of the libs.[img]i/expressions/face-icon-small-tongue.gif[/img]
Old Mar 16, 2007 | 04:46 PM
[img]i/expressions/face-icon-small-sad.gif[/img] Yea same here it's snowing and it stinks.
Sep 23, 2015 06:23 AM
ylomnstr
Sep 22, 2015 12:19 AM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
ylomnstr
Sep 4, 2015 05:02 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
