fuel guage not working
Old Mar 16, 2007 | 11:56 AM
frase's Avatar
Default fuel guage not working
The fuel guage on my 07 500 auto stopped working shortly after I purchase it and I am aware of a couple of other A/c's which have had the same problem. I was just wondering how common the problem is and is there a proper and permanent fix for it. Frase
Old Mar 16, 2007 | 10:45 PM
catdude's Avatar
the fuel gauge on my 500 never woked from day 1 [img]i/expressions/face-icon-small-disgusted.gif[/img], or I should say, it has never been very accurate.
Old Apr 2, 2007 | 08:20 PM
rem40xb's Avatar
I have a 2006 650 that had the same problem. I took it to my dealer and he said that the fuel guage doesent work on alot of the AC that he sells. It seems that the connection is bad and must be fixed on the sender or in the tank. He fixed mine Ross
Old Apr 3, 2007 | 10:05 AM
toehanus's Avatar
I have an '06 400 and the fuel gauge has never been accurate. It'll have fuel all the way up to the gas cap and it'll read about a half a tank.
toe
Old Apr 3, 2007 | 12:02 PM
rem40xb's Avatar
I have had several people tell me that the fuel guage on the AC is not accurate or it does not work. This seems to be a problem with the AC. My dealer said it is a simple fix. Ross
Old Apr 3, 2007 | 07:52 PM
Bastosako's Avatar
more than likely bad senders
Old Apr 3, 2007 | 08:08 PM
rem40xb's Avatar
I just purchased a new 400LE today and the first thing we checked was the fuel guage and it did not work properly. The mech sanded the connections and we were in business Ross
Old Apr 7, 2007 | 02:29 PM
JUJ's Avatar
JUJ
Regarding the malfunction of fuel gauge, it does not have to be the sensor, I got mine fix by the dealer and they informed me that it was due to one of the diods being installed in the wrong "direction" (ie, allowing current to pass only the "wrong" direction").
Other symptoms cured by this (if that is what was actually done) was poor output / bluddering engine. This especially occured on L range, it was as when you go in reverse quick but do not press the over ride button. This is how the engine behavied, but in L range.
Anyway, this may possibly help someone in which case I am happy.
/JUJ
Old Apr 10, 2007 | 11:03 AM
Breye's Avatar
I have had two replaced under warranty and now need it fixed again. I'm sure there must be others with the same problem. All Arctic Cat did was replaced Sensor, Fuel Level for /06 pat# 0570-112 $58.49 For 07/ part# 0570-141 $100.95 doubled the price on this piece of crap
Old Apr 10, 2007 | 11:29 AM
buckaroo50's Avatar
My 03 400 has never been accurate, I go by my odometer, (and I carry a 2.5 gal can), I know I can get between 100-120 miles from a full tank, depending on type of riding, so at around 60 miles I know it is time to start heading back.
I can take my cap off and look inside my tank to see how much fuel I have and if it is too dark I can just strike a match (or flick my bic) for more light - lol
