k&n Question
Old Mar 16, 2007 | 06:28 PM
twiztidatvrider's Avatar
Default k&n Question
Replaced my filter in my atv with a new k&n today . Went to give it a test run and i now bog down at 20mph and get no faster. Put the old dirty paper filter back in and runs fine. Whats the problem?
Old Mar 16, 2007 | 07:36 PM
Bloombastic's Avatar
I am no expert, but could it be that the K&N allows so much more air flow that you carb is not set up for it. I notice a difference in my idle when I have my k&n in versus my old paper filter. The EFI adjust for it though. I dunno for sure. Just a thought.
Good luck
Old Mar 16, 2007 | 07:44 PM
Kerbbirds's Avatar
It's probably got too much oil in it, clean it and re-oil "lightly" and see if it is ok, I've run them for years and this is the only problem I've heard of.
Old Mar 16, 2007 | 07:47 PM
I'll give the cleaning the oil out a try , is there any adjustments for the carb other than the idle ? If so where located cause i dont see them [img]i/expressions/face-icon-small-sad.gif[/img]
Old Mar 16, 2007 | 07:58 PM
Kerbbirds's Avatar
There is an air / fuel screw on them, probably covered with a brass cover, you can drill a small hole in the cover and thread a sheetmetal screw in it and remove the cover, air screw should be 1.5to 1and3/4 turns out, the k&n air filter usually leans them out and you can raise the main needle a notch and cure that.I'll bet the filter has too much oil though.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
