CG Question
Old Mar 16, 2007 | 10:19 PM
Daranello75's Avatar
Default CG Question
If I instaled 14" rims (replacing 12") thus increasing the ride hight by 1" and also increasing the with by 1" would the ATV center of gravity be:
Highter?
Lower?
the Same?
Thanks D
Old Mar 16, 2007 | 10:50 PM
DesertViper's Avatar
Default CG Question
All of the above.
The tire height will change CG, not the wheel diameter. You can buy a 25" tall tire with a 14" wheel that will lower the CG relative to a 27"tall tire with a 12" wheel. The larger diameter wheel when combined with an equal height tire will not change the CG, but will improve handling because the sidewall of the tire does not roll over as much on fast turns.
Old Mar 16, 2007 | 11:12 PM
Default CG Question
OK, so here my real dilema....my ATV has 12" rims. thinking of upgrading to 14" rims and tires. the dealer said it would be 1" wider and 1" highter........ So in the case would I be less stable? <!--IBF.ATTACHMENT_2633416--><!-- THE POST -->
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
