Sport Quads Discussions on sport quads.
Is 56hp possible on an lt-r450 with these mods?
Old Mar 22, 2007 | 10:31 PM
crazy1291's Avatar
Default Is 56hp possible on an lt-r450 with these mods?
I got my second issue (may 2007 issue) of ATVRIDER today, and i saw an article in there, "long term haul" "2006 suzuki lt-r450 wrap-up"
It claimed that it was able to "crank out 51-plus horsepower simply by adding a CT pipe and plugging in an M-80 performance module" smells like a bunch of bull
It also claims that after a JE13.5:1 piston, dynatek fuel programmer, "head got a valve job" (porting), "worked over the cylinder head", and a webcam.
Do you think that is even possible, i saw in another thread that the lt-r450 has 41 or 42HP at the crank stock, can you add 14hp just by doing that?
Old Mar 23, 2007 | 04:33 PM
Chevman's Avatar
easily... the chip adds 7 hp, the programmer can probably push out another 2-4, then add the hp gain you get out of doing the engine "guts" and the airflow the exaust system adds...
Im sure there is a way to get more than that out of it. All i plan on doing is adding the chip to the exaust system ive already got and leaving it at that. im not willing to sacrifice durabilty on it yet. As it is, all you do is add the chip to a stock LTR and its just as powerful or more powerful than any raptor.
Old Mar 23, 2007 | 06:57 PM
crazy1291's Avatar
Now i see the advantage of EFI, i doubt a 450r or yfz is that easy to get 10+ hp out of it
Ya i found out that the looneytuned Exhaust (dual exhaust) adds more than 10hp on an ltr
Old Mar 23, 2007 | 10:17 PM
Chevman's Avatar
what??? a duel exaust that i dont know about?!?!? can you find me a link?
Old Mar 24, 2007 | 08:47 AM
crazy1291's Avatar
here http://www.lteracing.com/dualexhaust.htm
scroll half way down the page
gains 12hp
Old Apr 1, 2007 | 09:54 PM
racequad250's Avatar
I think it possable because the Honda 450r with optional HRC kit has about 50 hp.
Old Jun 2, 2007 | 03:42 AM
TMay4's Avatar
well they cherry bomb is supposed to give u 7hp with juss takein off the lid and uncorking ur stock pipe and with a yoshi slip on i think its gives u around 12hp gain with the cherry bomb also but there is a set of dual exhaust pipes the looney tune pipes they say that their pipes give u 14 hp by their selfwith no other mods so i say it might be possible to get 10 outta the m-80 and that pipe u gotta look the ltr is corked down so bad in its stock form its not even funny they have it set up to where the 400's have as much top end but after u change a few things u will see the real power they have the thing im doin to myne is goin to mods3.com adding their stage 1 power kit with the EFI controller and buyin the yoshi rs5 offa rocky mountian and it will run me about 650.00 but i will have a spare cherry bomb to sell and make around 30 to 40 dollars back
Old Jun 11, 2007 | 07:09 PM
crazy1291's Avatar
so 70hp is quite possible then, with cams, porting, 13.5:1 compression, head work, LTE duals, the chip, the programmer, etc
I wonder at what HP reliability becomes an issue.......... 80?
Old Jun 19, 2007 | 01:38 AM
buck183's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: TMay4
well they cherry bomb is supposed to give u 7hp with juss takein off the lid and uncorking ur stock pipe and with a yoshi slip on i think its gives u around 12hp gain with the cherry bomb also but there is a set of dual exhaust pipes the looney tune pipes they say that their pipes give u 14 hp by their selfwith no other mods so i say it might be possible to get 10 outta the m-80 and that pipe u gotta look the ltr is corked down so bad in its stock form its not even funny they have it set up to where the 400's have as much top end but after u change a few things u will see the real power they have the thing im doin to myne is goin to mods3.com adding their stage 1 power kit with the EFI controller and buyin the yoshi rs5 offa rocky mountian and it will run me about 650.00 but i will have a spare cherry bomb to sell and make around 30 to 40 dollars back</end quote></div>
Huh?
Buck
Old Jun 19, 2007 | 02:03 AM
Doctorturbo's Avatar
GOT BOOST!
<div class="FTQUOTE"><begin quote>It claimed that it was able to "crank out 51-plus horsepower simply by adding a CT pipe and plugging in an M-80 performance module" smells like a bunch of bull</end quote></div>
I'll be the first to say, "ya, I think it's bull". There is not much left in these engines for bolt on's. They are a factory race engine.
I look at it this way. It's easy to double the HP of lets say a 200 horse 350 small block. Now take a full on factory race engine. Lets say an LS6. See if you can double the HP on one of those. Ain't going to happen.
It's very hard to get an more HP out of a race engine.
Unless these things are really plugged up pipe wise from the factory, it's going to be a tall order.
