400ex engine help.....
Old Mar 22, 2007 | 11:22 PM
beermansixt9's Avatar
Default 400ex engine help.....
Last sunday i finished a overhaul on my quad. I put new piston in and had a valve job done and engine runs good but seems to make a slight ticking sound in the top end any help??
Old Mar 22, 2007 | 11:44 PM
mjm540ii's Avatar
I'm not sure, but i think on 400ex's the decompression release sometimes gets stuck with one of the valve rockers(?) somtimes and will cause a steady tick. ( I think i read that in Clymer) and i think I either read or heard that when this happens, leave the quad off and rock the bike forward and backwards (in gear and with the clutch out). Give it a try.
Old Mar 23, 2007 | 12:08 AM
Ill give it a try in the morning. because it did not tick or make any nose before. it just quit running. then i rebuilt it. would you think the rocker arms would of went bad? its not real loud but i wonder if i should ride it like that?
Old Mar 23, 2007 | 12:25 AM
mjm540ii's Avatar
Like I said, I'm not sure exactly what part of the valves/rocker arms that the decompression lever gets hung up on. Although you said you got a valve job, it wouldn't be a bad idea to check your valve clearances too. I would give you the clearance specs, but im up at college, and my manual is at home.
Good luck
Old Mar 23, 2007 | 10:21 PM
ok.... so i tried the whole rock back and forth deal... nothin... still ticks?? my buddy said it could be a loos header pipe!!! not sure.
Old Mar 25, 2007 | 03:28 PM
mjm540ii's Avatar
sorry man, well it was worth a try. have you checked your valve clearances? take a look at that header, good luck.
Old Mar 25, 2007 | 04:44 PM
Lifes2ShortRideHard's Avatar
Hey mine is doing the same thing after a rebuild. I put a 426 kit in mine and it all of sudden started ticking. At first i thought i needed to run higher octane gas than 92 octane. So i ran 97 octane and it still ticks. so when you figure the problem out please tell me what it was thanks.
Reactant
Mar 30, 2022 02:08 AM
Asaran
Oct 8, 2015 11:14 AM
metal249
Jul 28, 2015 09:35 AM
metal249
Jul 24, 2015 01:00 PM
95wolv
Jul 21, 2015 12:25 PM
