Sp 600 clutching specs and clutching mods
Old Mar 23, 2007 | 09:20 PM
BuddyP's Avatar
Default Sp 600 clutching specs and clutching mods
Does anybody know the stock spring rates, weights and helix angles?
Also what kit combo or clutch combo seems to work best for waking up this machine?
Old Mar 27, 2007 | 06:13 PM
BuddyP's Avatar
anybody?
Old Mar 27, 2007 | 07:23 PM
TennesseeTider's Avatar
I put a heelclicker in mine and a primary clutch off an 06 800 and it woke it up some with not as much lag on take off and not as much need to use low. guys at atvquadsquad dot com (Cajun and Cob) are the REAL experts on clutching
Old Mar 28, 2007 | 11:23 AM
BuddyP's Avatar
Thanks, do you know what the stock weights, spring rates and helix angles are?
Old Mar 28, 2007 | 01:39 PM
SPORTSMAN70003's Avatar
Stock weights are 10MH, stock spring is blue with a green stripe and the spring rate is 5-117lbs and I'm not sure what the helix angle is on the 600.
Old Mar 28, 2007 | 06:10 PM
BuddyP's Avatar
Thanks for the info.
Anybody know helix angles?
Old Mar 28, 2007 | 07:22 PM
Again, go to www.atvquadsquad.com and go to the Polaris forum and ask. Cajun or Broken Arrow will get you what info you need.
1ArmBandit
Sep 8, 2015 08:59 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
JakeXBL
Sep 5, 2015 01:08 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
cdstang
Aug 31, 2015 07:52 AM
