Worn Tie Rod Ends
Old Mar 29, 2007 | 07:52 PM
JKW's Avatar
JKW
Default Worn Tie Rod Ends
My 02 SP 500 has a shimmy at higher speeds, on hard pack, and is getting worse. While I was greasing it I checked the rod ends for play. 25 years in auto repair business, on a car they'd be junk, and fail inspection. Never checked them before, am I correct assuming they should have little or no play? With 430 mi / 133 hrs this seems premature failure, and about 130 of the 403 miles where put on ice fishing, riding on a frozen lake would be easy miles! I haven't shopped around but, $30.00 a wack, all 4 are sloppy, seems a little steep! Thanks
Gona take it out Sunday and whip on it anyway!
Old Mar 29, 2007 | 08:27 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you sure its not your tires causing the vibration/shimmy. the older style trail blazers were famous for junk tie rod ends and i think you had to replace the whole end and arm. big $$$
Old Mar 29, 2007 | 08:34 PM
Potent's Avatar
I just replaced mine on my daughters TB. I bought some from graingers ( Heim Joints w/ 1/2x20 threads using my wifes buisness account at 7 bucks each. They should be similar to a car.... Smooth movement w/ no free play.
Old Mar 30, 2007 | 01:15 AM
SCRAMMYTODD's Avatar
I think I put 2 complete sets on my old Scrambler in 3 years. But they were hard 3 years. Probably comparable to 10 years on some other peoples bikes. LOL
Old Mar 30, 2007 | 04:23 PM
suds's Avatar
I eat thorugh Tie Rod Ends on my machine so fast (02 Scrambler). I find that I go through Tie ORd ends and steering column bushings evey 1-2 years. With your machine being an 02 it is probably time for replacing. When you you replace make sure that your wheels are properly aligned or you will pre-matuelry wear through them .
Old Mar 30, 2007 | 05:11 PM
JKW's Avatar
JKW
Potent, That's one thing I had in mind. Do yours have rubber boots over them? Thanks
Do the stock rod ends have play new? This is my first ATV. When I was putting the front lift in, think I remember the Rt side inner had a little play. That one is really loose now, and the others have play too.
Lastly, a couple of people are selling replacements on Ebay. Has anyone tried them? They look like OE and have the sealing boots, one guy claims his are stronger, don't know if that means more durable?
Old Mar 30, 2007 | 05:23 PM
JKW's Avatar
JKW
Potent, If I read the remainder of your reply it would've saved me 15 mins of 2 finger typing! Duh !! Thanks again for the info.
Old Mar 30, 2007 | 07:05 PM
scramblerXrated's Avatar
when i replaced my tie rod ends a year ago(first time since new), i bought stock replacements. one thing i did after installation, was to use a grease needle, and slip it under the boot along the actual tie rod. pump it full of grease.
they have been on for over a year now, and they still are like new. no play.
another thing to check before you go and spend a buncha money, is the main steering stem bushings. they will cause alotta steering play if they go unchecked as well.
X
Old Mar 30, 2007 | 09:38 PM
furnaceman's Avatar
Do you have a part number on those?
I was thinking of doing the same for mine! just was wondering where to get them. You would think with me being in heat and ac And working right next door to graingers. I would have thought about checking there.
Old Mar 31, 2007 | 09:06 AM
Potent's Avatar
I used grainger part number 6G175 which is the right hand threads 1/2x20 and 6G207 which are the left hand threads. You will need 2 of each. I also had to get some sleeves part number 1X871 because the inside diameter hole was 1/2" and I had to reduce them down to 3/8". I took the rubber boots off the old ones and slipped them over the new ones. It took a little effort and WD-40 but it should keep a majority of the crud out. These are much beefier than the stock ones so the should last for quite a while.
