lower rpm engagement
Old Mar 30, 2007 | 06:20 AM
wayout's Avatar
Default lower rpm engagement
2006 magnum,i want a lower rpm engagement,what do i change,weights or springs..any info would be helpful,thanks...wayout,out....................
Old Mar 30, 2007 | 07:02 AM
ftwflh's Avatar
You can get lower engagment with heavier weights but this will take away from your topend.
I would try the EPI pink primary spring it will help you out all the waY around.Lower engagment plus better top end.
Old Mar 30, 2007 | 07:14 AM
towpro's Avatar
I am new to Polaris with a 2005 ATP 500 Leftover. I came off a little Yamaha bear tracker 250cc with manual trans.
Mostly i use my ride for yard work, snow plowing and riding to the neighbors house (long driveway). Mine seems to cruse at 4000 rpm all the time, which I feel is a little high.
I am guessing from what I am reading that I can change a clutch spring and lower the RPM? If I use low range anytime I am moving slow, hauling weight or snow plowing, will lowering the RPM cause any additional wear?
Oh, and for those of us who are new around here, what or who is EPI?
Thanks
Old Mar 30, 2007 | 09:56 AM
sheepdogMSP8117's Avatar
Erlandson Performance Inc.
Old Mar 30, 2007 | 08:31 PM
towpro's Avatar
thanks, Now I got to check my service manual out so see what is involved.
Old Mar 30, 2007 | 08:46 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you can change your primary spring to get lower r's but i think most of them run around 4,000 rpms when crusing at least it seems around there on my 2. just my .02
Old Mar 30, 2007 | 09:25 PM
SeaBee's Avatar
On the wifes '05 330 Mag, I changed the primary weights to 10-56 and installed an Aaen blue secondary spring.
Old Mar 30, 2007 | 09:31 PM
ftwflh's Avatar
Why so heavy of weights?With stock primary spring?
Old Mar 31, 2007 | 08:33 AM
SeaBee's Avatar
The Wife liked the lower engagement rpm and less motor noise. Had to put the Aaen blue secondary spring to keep if from shifting out too early. Keep in mind this was done to make the Queen happy. I used the weights out of my 700. I had changed them to 20-62 for lower engagement. We have a little over 1600 miles on them with the original belts. Del Hartline
Old Mar 31, 2007 | 08:42 AM
drlang's Avatar
Personally, I think all polarises come in too low already. I can't Imagine going any lower, but that is just me. Doc
exmotocrosser
Sep 13, 2019 06:12 AM
flyin-lowe
Dec 1, 2017 03:18 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
