what to do after removal of predator air box
Old Apr 2, 2007 | 01:15 AM
DjSeabass's Avatar
Default what to do after removal of predator air box
ok u guys i need help i just finished installing a k&n sn-2550 filter, and finished dyno jetting stage 3 on my quad runs great really , but on problem i still have the stock airbox with the filter why use it if i dont need i by the the way i also got a coverfor the filter. yeh so why need the airbox so i removed the airbox and that big tube that sucks in air but the little tube on the right i notice thtas the one that throws oil in my airbox somtimes. what should i do leave it hanging, is there somthing i could buy for it or leave the box. need help fast cuase tommorow goin to red sands and ride pls pls need advice
Old Apr 2, 2007 | 01:42 AM
FatHolly's Avatar
The smaller tube is normally the casevent... get a small filter and mount it where it won't make a mess. The larger tube (or snorkle) may be necessary for proper air flow. In most bikes it creates a vortex and gets the air flowing smooth. When you remove it,the air tumbles into the carb instead of flowing smoothly. I don't know about your particular application, but I would guess that it would be better to keep it with the filter at the end... I could be wrong but I haven't seen many bikes that benefit from removing the intake snorkle. The Predator uses the same carb as the Can Am DS650 and I can tell you that removing the snorkle on the DS makes less power. Hope that helps and good luck getting her ready for the trip.
Old Apr 2, 2007 | 01:44 AM
DjSeabass's Avatar
thanks alot
Old Apr 2, 2007 | 06:38 PM
Bradracer18's Avatar
Removing the tube, does NOT make less power!! If you put a strait clamp on, it does. You need(for a clamp on), a Twin Air filter.......it has a shorter tube.......also, you'll need a crankcase breather.
Old Apr 2, 2007 | 07:30 PM
DjSeabass's Avatar
do u have one if so were did u buy it
Old Apr 2, 2007 | 09:04 PM
crazy1291's Avatar
does that mean that you can put efi on a pred just like you can on a ds650?
Old Apr 3, 2007 | 08:35 PM
I have one........I bought it at www.nicholascycle.com at their store though.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Elkaholic
Sep 6, 2015 02:44 PM
