questions: Best place to buy tires and size questions?
Where is the best place to buy tires for my DS? (Holeshots or Razr's)
Currently, I a, running 22x10x9 in rear and 22x7x10 in front.
If I go to taller tire in front how does that effect handling?
Appreciate any input
I would look at rocky mountain atv to see what they have available, thats where I buy most of my stuff...I would not recommend going any taller for the front tires unless you are racing gncc or something...For the rears I would run problably a 20 or 21 at the most...I have had both holeshots and razr's and currently run razr's on my ds and both are great tires so either way you go you are going to have a great tire, but honestly I thing the razr's last longer because the rubber seems to be a little stronger and doesn't wear as fast.
Good deal on tires
I would check these out. You can make them an offer if you don't like the listed price, but the cheapest I've seen them let this set go for is $270. Still not a bad deal.
We do mostly desert riding so we run 23 fronts and 22 rears regardless of if it's a dirt or a sand tire. Just better handling, flotation, and gives you a little more ground clearance.
I agree that the RAZR2 is probably the better tire, but the Holeshot XCT is also a 6 ply.
toonces
Oct 16, 2019 12:11 PM
JackTheKing
Jul 14, 2015 09:09 PM
