2004 400ex
Old Apr 8, 2007 | 12:24 PM
certauto's Avatar
Default 2004 400ex
I have an 04 400ex the battery was pretty dead so i boosted it and it started but wouldnt stay running so i put it on a battery charger and this morning went to start and it crank a few times then nothing no clicking or anything and the push button is a little sticky then the nuetral light doestneven come on with a booster on it? is this a case of the battery is just so dead or is it an electrical problem any help would be great btw this is a great site and have been lurking for a while
Old Apr 8, 2007 | 12:54 PM
hondabuster's Avatar
Default 2004 400ex
Check the fuse.
Old Apr 8, 2007 | 12:58 PM
certauto's Avatar
Default 2004 400ex
Forgot to mention i did check the fuse it is a 15 amp should it have a bigger one? could it be the starter?
Old Apr 8, 2007 | 01:57 PM
ACFreerider's Avatar
Default 2004 400ex
I'm pretty sure you just blew the fuse. What was the booster set at?
Old Apr 8, 2007 | 02:21 PM
certauto's Avatar
Default 2004 400ex
if the fuse was blown would the headlight still work? i pulled it and looked at it and the wire wasnt broke should i put a higher amp in it? i forget what the booster was set at
Old Apr 8, 2007 | 02:23 PM
Default 2004 400ex
Does the headlight still work? And I'm not sure but I don't think it would.
Old Apr 8, 2007 | 09:53 PM
Lifes2ShortRideHard's Avatar
Default 2004 400ex
check to see if your ground wire is still attached mine did the same thing. Easy to overlook the little things.
Bernhard
Sep 25, 2015 12:45 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Sw00p
Sep 24, 2015 02:50 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
