jet fuel
Old Apr 8, 2007 | 02:29 PM
Tdizzle's Avatar
Default jet fuel
has anyone ever used that jet fuel blend in there quad i used it in mine and it made it so fast
Old Apr 9, 2007 | 12:09 AM
JRM's Avatar
JRM
Default jet fuel
do a google search, you will find that anything over 95 octane in a stock engine will actually reduce power, modified engines can enjoy 100+ with great results. As long as its not spark knocking or pinging hard, your fine. I run 87 octane in my Rubicon as anything more is just not needed unless I here spark knock, or pinging.
Oh, and "jet" fuel intended for turbine jet engines is pretty much diesel with some extra cold weather attentive's thrown in, aviation fuel intended for prop piston engines is what your looking for. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 9, 2007 | 01:17 AM
OhHell's Avatar
Default jet fuel
You may have used avaitation fuel.
Jet fuel is nothing but high grade kerosene.
Old Apr 9, 2007 | 02:55 AM
Doctorturbo's Avatar
GOT BOOST!
Default jet fuel
I think Jay Leno run it in one of his bikes. [img]i/expressions/face-icon-small-happy.gif[/img] He uses it at 100% though.
Old Apr 9, 2007 | 10:34 AM
theCATman's Avatar
Default jet fuel
Yea, I run jet fuel all the time. I have 32:1 compression so I need it for my engine. Errrr.... was that 32:1 pre-mix ratio??????????????????[img]i/expressions/face-icon-small-confused.gif[/img]
Old Apr 9, 2007 | 04:28 PM
quicksilver's Avatar
Default jet fuel
the rule of thumb for octane is use the lowest octane fuel you can use without spark knock/pinging. Lower octane burns quicker and ignites quicker, high octane resists ignition more so the high compression engines dont pre-ignite it just from the compression.
Old Apr 9, 2007 | 08:55 PM
Tdizzle's Avatar
Default jet fuel
well i used this octane booster made with jet fuel and nitritos and my recon hauled everliving ***
Old Apr 9, 2007 | 10:18 PM
BourneTrailBlazer250's Avatar
Default jet fuel
Octane booster, jet fuel, and N2O? Now that's something you don't see everday...
Old Apr 9, 2007 | 10:31 PM
Tdizzle's Avatar
Default jet fuel
you can buy it at autozone
Old Apr 9, 2007 | 11:22 PM
JRM's Avatar
JRM
Default jet fuel
""I think Jay Leno run it in one of his bikes. He uses it at 100% though""
Yup, he does run true jet fuel, or diesel, home heating oil- whatever he can find as his bike has a true "jet" engine.
http://www.marineturbine.com/motorsports.asp
