2001 Acat 400 fuel feeding...
Hello "helpfull" gang...
I had my 2001 ACAT 400 4x4 carb cleaned
and now I am having some fuel feeding problem...
Here is a description of the problem:
If I put the fuel switch to "on" position,
It seem that the engine is not getting enough fuel
and is getting a lack of power whenever I push on the gas throttle.
I also notice that if I push on the primer button, The fuel
is not getting to the carb.
If I put the fuel switch to "reserve" position,
The engine is getting OK. And at start, the primer button
is getting juice to the carb and fire very easily.
If I wait a couple minute, and switch back to "on" position,
it's getting again a lack of power and want to stop.
May I always run on "reserve" position?
What is the difference between "on" & "reserve" position?
Should I drain gas in the tank?
What about having to clean the "float bowl"?
I am not a mechanic, but I'm getting use to like
fooling around with engine since I owned this ACAT 400...
THANK YOU!
THANK YOU!
Sounds like the selector switch got some gunk in it. You could try to take it off and clean it. Probably would not be a bad idea to take the tank and everything off and flush it out good. When you put it back on then put some carb/injector cleaner in with your gas. I think a good cleaning from the carb back to and including the gas tank may help out.
Here is what I do on a regular basis - I have a 6 gal gas can and I mix the recommended amount of Marvel Mystery Oil per gal. I do 1/2 the recommended amount of dry gas, and 1/2 the recommended amount of carb/injector cleaner and 1 cap of 'stabil' for every gal. I always fill my tank from home with the gas from the 6 gal can. If I stop on a trip for a top off from a gas station I don't worry about it. I use that same gas can for my lawnmower, snow blower, an my little outboard etc... My snowblower I bough new in 1981 and has never had the carb off for cleaning or anything... I have never had any carb off for cleaning for that matter, if my memory is not failing me too bad. During sitting months then I just add a couple caps of 'stabil' to the snowblower, lawnmower or which ever one is going to be sitting for a period of time, or I will try to run it dry and out of gas before storing. Works for me... has for years, I do a similar thing with my auto's. The biggest thing is the Marvel Mystery Oil. If it burns gas then it gets a dose of Mystery Oil.....
bradco
Aug 21, 2015 08:11 PM
