Raptor 660 case cracked
Old Apr 9, 2007 | 06:04 PM
zombi's Avatar
Default Raptor 660 case cracked
Lots of the rappys I see have the case cracked where chain has flown off & busted case...how does this happen?Does the case savers not work???My used bike has same problem the chain came off & hit the side case & knocked off the top screw hole, now how can I use a case saver to prevent MORE damage next time it happens???Any help guys?Thanks
Old Apr 10, 2007 | 11:29 PM
BBR650's Avatar
Is always changing bikes.
jb weld it back on and the worse that could happen is it bust the jb weld off........i had that problem on one of mine. make sure to keep after chain adjustment,alignment and lubrication. you shouldnt have that problem if doing that. the idea of the case saver tab being jb welded back on is at least it wont tear the case up any worse. it will come loose instead of crackin it worse.
Old Apr 11, 2007 | 09:16 AM
zombi's Avatar
WOW ,never thought of that.Thanks
Buy the way my black ground wire on the side of engine has a smaller wire attached to it...I thought it only had the big ground.Im a 2002 660.Maybe someone had something added.Do you have more than one ground wire?Thanks
Old Apr 12, 2007 | 01:14 AM
BBR650's Avatar
the one under the sprocket should only have one wire. it is for reverse. i would almost bet someone grounded it out to get rid of the rev limiter in reverse.
Old Apr 12, 2007 | 10:14 AM
zombi's Avatar
No,Man not that wire the big black one on the side of the engine case.Thanks
bmxatv10
Oct 14, 2022 06:23 PM
Troylee216
Sport Quads
Sep 28, 2015 09:34 AM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
