2004 400ex
Old Apr 16, 2007 | 12:09 AM
carte's Avatar
Default 2004 400ex
I know the gearing is 15/38 but i want to know how many links the chain is, and how many would it need to be if i were to go up three teeth in the rear
Old Apr 16, 2007 | 01:54 AM
hondabuster's Avatar
Default 2004 400ex
Stock is 94 links. And according to the Rocky mountain atv site, add two links per every 2 tooth change. So a 98 link chain is needed.
Something else to consider..i just changed the front sprocket to a 14, and i ended up with almost the same ratio..and the chain is stock. Just changed the front sprocket,( from Rocky, for 8 bucks,) and its just fine. Alot cheaper, and just as good as changing the rear sprocket and chain.
Old Apr 16, 2007 | 03:34 PM
carte's Avatar
Default 2004 400ex
first off i appreciate your reply. the link info is useful. but i am not only jumping up teeth in the rear sprocket i am also lowering the front . in order to have a low gear bike for about a 100 drag. also how much of a difference did you see when you dropped to a 14 tooth front. thanks
Old Apr 16, 2007 | 04:03 PM
Default 2004 400ex
If youre also doing the front, then you could probably get away with a 96 link chain.
Havent ridden it much since i did the sprocket change,but it should be a good 7% difference in torque to the wheels. I did the change mainly to restore some power which will be lost, when going up in altitude this summer, at St Anthony. Im not very concerned about top speed, so i dont mind the gearing down, and it should help in the slow trail riding in MN, as i wont have to slip the clutch much to keep it moving at a slow pace.
If you do both sprockets, it should really pull hard...but youll lose about 8mph on the top end.
Bernhard
Sep 25, 2015 12:45 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Sw00p
Sep 24, 2015 02:50 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
