JE 11.5 to 1 Piston weight.
Old Apr 17, 2007 | 01:59 PM
TheStir's Avatar
Started riding ATVs in 1974!
Default JE 11.5 to 1 Piston weight.
My postal scale only goes to 1/10 OZ so its not the most accurate, but here are the weights!
Stock piston and wrist pin = 19.5 oz
JE piston and wrist pin = 17.2 oz
So the JE is 2.3 oz lighter or around 65 grams...
Just more info,
Scott
Old May 8, 2008 | 10:28 PM
OMR's Avatar
OMR
Is Oldmanracing! Also the inventor on the DS650 carb Mod!
Measured the stock with pin and clips, no rings 526.17 grams
Measured a JE 11.5 with pin and clips, no rings 462.66 grams
The JE 11.5 is thus 63.51 grams lighter
Based on Eric's gram weight for the stock, the rings would weight about 29.06 grams.
This puts the JE at 491.72 grams.
I have two motors in my basement for rebuild. I will cc the heads and the piston to find out what the real static compression computes.
My only complaint so far is that the deck height on the side quench pad is .005" higher than the quench pads by each set of valves. Trying to set the quench at .040 may have to be compromised.
OMR
Old May 9, 2008 | 02:05 AM
TheStir's Avatar
Looking forward to what you come up with.
Old May 11, 2008 | 11:09 AM
ERBEDS650's Avatar
I awaiting on Preachers Verdict also on my piston, since its going through a rebuild, I would like to go to a CP piston 14 to 1 x 105mm
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
