Pro Armor kill switch help?
Old Apr 20, 2007 | 12:25 AM
JMann2380's Avatar
Default Pro Armor kill switch help?
I am thinking of getting the Pro Armor kill switch and had read there is a difference between normally open and normally closed? Most quads are open but the DS is closed... is that right? Will the Pro Armor work with the DS? Whats the best way to wire it up?
Thanks,
Josh
Old Apr 20, 2007 | 11:22 AM
pipelayer's Avatar
I'm a Plumbing contractor and I have some old friends that always called me Pipelayer for some reason?
Yes pro armer is on my DS and its simpal to install, just re-post after you have it and I will look at my bike.
Old Apr 29, 2007 | 10:41 AM
JMann2380's Avatar
Ok got the switch...how do I hook her up?
Old May 1, 2007 | 05:27 PM
JMann2380's Avatar
bump
Old May 1, 2007 | 05:40 PM
pipelayer's Avatar
JMann I spliced the wire coming out the end of the pro armer to the wire behind the dash that is black/white stripe ,that wire is from the kill switck on the left handlebar. then I took the other wire from the pro-armer and grounded it to the bolt that holds the plastics and the oil tank to the frame on the left side. If I confused you call me Brian (916)521-4733 good luck
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Halffast17
Sep 11, 2015 02:30 PM
alzgarvin
Sep 11, 2015 08:53 AM
Albertaboyy
Sep 9, 2015 09:51 AM
toonces
Sep 5, 2015 01:14 PM
