oil
Old Apr 21, 2007 | 09:31 PM
andrewallen's Avatar
Default oil
im changing my oil for the first time today. how many quarts dose a 03 arctic cat 400 4x4 take???
Old Apr 21, 2007 | 10:13 PM
buckaroo50's Avatar
Default oil
3.25 US quarts or 2900ML, check the oil without screwing in the dipstick.
Old Apr 22, 2007 | 01:07 AM
Default oil
i have another question too. I went to my arctic cat dealer and he sold me a oil change kit for my year and type of arctic cat and when i changed the oil filter the one that came off is shorted that the one i put back on and on the box it came in it said it would fit a 400 so can some one tell me if i should get a new oil filter or if they just started to make a new one???
Old Apr 22, 2007 | 01:14 AM
buckaroo50's Avatar
Default oil
I don't know, about the shorter filter, use it and don't put all the oil in, try only 3 quarts and check the level.
I use a Fram filter on my machine but I have used AC filters before.
Old Apr 22, 2007 | 03:12 AM
swampyjunior's Avatar
Default oil
I think they replaced the shorter oil filter in 05 or 06 with the newer one. The new AC oil filter number for the 400/500 is p/n 0812-034. It is about 1/2 inch longer and has a slightly smaller diameter than the old filter.
I personally like the newer design as it is easier to put on and take off with your hands. No wrench needed if its done right.
Also, in case you did not do it already, I find it easiest to remove the skid plate when changing the oil so I do not get oil all over the skid plate. This way I do not have to remove the little plug to drain the oil from the filter, I just remove the filter and catch the oil than runs oil in an oil pan. Plus, every other oil change you should remove plate your oil plug screws into and clean the oil pump intake screen. Especially after the initial break-in.
SJ
Old Apr 22, 2007 | 09:12 AM
Default oil
alright that yea my new one is longer and its a little thinner too thanks!!!
Old Apr 22, 2007 | 09:44 AM
v2rider's Avatar
Default oil
Another recommendation, i would switch to a good synthetic oil.
