Scrambler Axel Nut
Old Apr 26, 2007 | 09:15 PM
garrett5462's Avatar
Default Scrambler Axel Nut
Does anyone know if the Axel nut on a 2002 scrambler happens to be reverse threads? cuz im trying to change the carrier bearings. I took off the snap ring and then that piece that slides off the nut, and the foam seal. Now, i have to get the "Sprocket Hub Nut" i think its called off. i cannot get it off. i wasnt sure if it was reverse threads for some reason. i looked at them and they look normal.
Old Apr 26, 2007 | 09:30 PM
im pretty sure once that nut is off, the axel will just slide out from the left side.
Old Apr 26, 2007 | 11:03 PM
anyone happen to know before i just get the biggest adjustable ive got, put a 4 foot pipe on it and just give it hell? i dont see why it wouldnt be regular threads but you never know. thanks.
Old Apr 26, 2007 | 11:30 PM
ftwflh's Avatar
Best thing I have found to do is cut the nut off and replace it.
Old Apr 27, 2007 | 12:08 AM
03scrambler500's Avatar
that nut is fine thread and gets rusted on there very quick. i heated mine up to get it off and i still hade to use a big wrench when i reinstalled it i put antisieze on it i hope that helps for next time.....it is regular right hand thread just takes losts of torque to get off
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
