84 honda 110 atc.
Does it have the splined tensioner under the chain guard like the older ones? If it does, you should be able to loosen a bolt or nut on the right side and move the slider up which is attached to the tensioner by a shaft that goes through the frame.
Yes, it does, everything is much better now, I think now I just gotta stop the gas leaking from the carb <g> Do you know if there is some secret place to get parts for these older atc? BTW: Yours are Beautiful.
Thanks for the advice.
E-Bay is about the best place to get parts. This place also has some. http://www.atcheaven.com/index.htm
