94 sportsmens 400 motor locked up. help
Old Apr 26, 2007 | 11:37 PM
becks's Avatar
Default 94 sportsmens 400 motor locked up. help
well i got a project, i bought a 94 sportsmen 400 with a stuck motor. now i am mechanically inclined but i am not sure where to start. i am very unfamilar with 2 strokes. any starting advise would be greatly appreciated. thanks
Old Apr 26, 2007 | 11:42 PM
booboobear's Avatar
I had a 352 wedge motor freeze up, I poured some air tool oil in the cylinders, let it set for awhile,pushed the truck down the hill popped the clutch and woolah, broke loose, didnt wreck the rings or anything, ran great after wards, you can try it whats it going to hurt, my . 03 cents
Old Apr 26, 2007 | 11:58 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Guys at work say to put some Kerosene down the CYL. and let soak...........Same idea though!!!!...........Caper..............
Old Apr 28, 2007 | 10:28 AM
drlang's Avatar
There are quite a few reasons for an engine to lock up. In my opinion, disassemble and make an educated guess. Less headaches in the long run. Doc
P.S Where are you in MN. If you get sick of it I'm looking for one of those for a project. Doc
Old Apr 28, 2007 | 11:06 AM
becks's Avatar
pm sent doc, i think i am already sick of it! [img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 28, 2007 | 11:25 AM
x_scrambler3's Avatar
I live in Pine River if you are kinda close to here I can give you some help. It could be one of two things one piston has sized up an need a top end rebuild 2 could be the counter balance went bad witch is a bigger issue.
Old Apr 28, 2007 | 07:19 PM
ftwflh's Avatar
Good luck Doc[img]i/expressions/face-icon-small-wink.gif[/img]
Old Apr 28, 2007 | 07:54 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
depends, did it stick because the oil injection failed and sezied the crank??
Old Apr 28, 2007 | 11:33 PM
ftwflh's Avatar
Doc want another drag bike /sleeper[img]i/expressions/face-icon-small-wink.gif[/img]
fd24
Jan 16, 2019 08:59 AM
strokesb16b
2) Chassis problems..
Sep 15, 2015 09:19 PM
JDawg8309
1) Engine problems..
Sep 12, 2015 02:24 PM
GODsRebel
11
Sep 8, 2015 12:07 AM
