07 Rincon engine noise??? Ticking
Old Apr 29, 2007 | 10:58 AM
Razr24's Avatar
Default 07 Rincon engine noise??? Ticking
Ever since I bought my 07 rincon it has this engine tapping ( ticking ) noise when at idle. Get on it an go and it seems to go away. I have 200 miles now an it seems to be getting louder @ idle. Haven't took it for its 1st service yet.
Do you think it needs the valves adjusted?? Or it that how they are suppose to be sounding?
Old Apr 29, 2007 | 11:19 AM
RedRubi's Avatar
I believe you're hearing the compression release mechanism in the head. Mine did it at idle while in gear, and mostly went away when I put it in neutral. I's nothing to worry about.
Old Apr 29, 2007 | 03:18 PM
JeffinTD's Avatar
It seems most Hondas I have ridden to make a little noise at idle. Assuming what you are hearing is just a soft ticking, I wouldn't worry about it.
Also, at 200 miles, yes, you should adjust the valves. My intakes were a touch loose at the first check... Make sure the lock nuts on the tie rods are tight while you are messing with it.
Old Apr 29, 2007 | 05:01 PM
ForemanDan's Avatar
My 06 does the exact same thing even after the valve adjustment.
Nondem
Feb 22, 2020 12:20 PM
ronnierhino06
Nov 9, 2015 12:56 PM
Big bousse
Sep 26, 2015 10:42 AM
MNatv89
Jul 7, 2015 11:36 AM
D-Hagz
Jul 4, 2015 02:19 AM
