BANSHEE MODS!!!...
Old Oct 20, 1999 | 10:44 PM
blue_banshee's Avatar
i am wondering what mods all of u have on u'r banshee beast??...i am kinda ggonna use this as a
guide to my next mods...if there is something u dont like about a mod u have then please say
so...thanx
Old Oct 25, 1999 | 03:07 AM
jeffsouza's Avatar
We've got a few Banshees in our family, so I'll tell you the mods we liked and in what order I'd do 'em.
1. proflow filter kit. Stock is risky.
2. Water temp gauge
3. T5s + jetting kit. Gotta have 'em!
4. Boyesen reeds on stock cages
5. works or axis shocks/+2 a-arms
6. 28mm PWK carbs (haven't done this yet)
7. pro design intake
8. port cylinder/ mill head (or interchangable dome head)
I think you would be happy with all these mods. I'm interestest to hear what other people have done and liked too.
jeff (banshee, Lt250, Lt80)
Old Nov 7, 1999 | 04:23 AM
twinbanshees's Avatar
fmf fattys
k&n clamp ons w/outerwares
fmf rad valves
boost bottle (almost no gain)
bored carbs
trinity stage4 head (16cc domes)
6" extended swingarm
renthal bars
haulers (for sand)
ported head
sprockets
crome(it makes you fast....looking)
and I just read about a speedometer that you can retrofit from a bicycle speedo. It works!!!! its kinda hard to fit the magnet in somewhere that spins about a mm away from the sensor though.
Bruce 87,92 banshees
Old Nov 7, 1999 | 05:24 PM
sndnyrface's Avatar
FMF Fatty's
Boyesen power reeds
Pro Flow filter kit
310 mains
....so far
Skene '00 Banshee
Old Nov 7, 1999 | 07:14 PM
SaMs0nOLD's Avatar
99 Banshee
LRD Pipes & silencers
CT TCS front shocks
re-valved rear shock
Boyesen Rad Valves
DG skid & glide plate
DG nerf bars
DG front bumper
Denton Steering dampner
Pro Design Pro Flow with foam filter
Pro Design super cooler
Pro Design power shifter
Gearing 13/41
Future mods
tires, cool head, handle bars, parking brake block off plate, and some other stuff.
87 Banshee
Stock
87 Banshee
99 Banshee
Old Nov 7, 1999 | 11:36 PM
Rocky's Avatar
98 Banshee
LRD pipes and silencers
LRD 380 big bore kit
Crank treued and welded
Boyesen rad valve
LRD prepped 28pwk Keihen carbs
Pro Design Cool Head 18cc domes
Pro Flo with a FOAM FILTER
Hinson Clutch Basket
Hinson clutch side cover
LRD 3 piece stator cover
MSD ignition
Axis front and rear shocks
Pro Taper Bars RTC levers
Roll Design +2 and +1.5 a arms
Old Nov 8, 1999 | 02:44 PM
brandon's Avatar
1. C&O 370 long rod motor with override tranny.
2. Cool head with 16cc domes
3. FTZ full race ignition(battery fired with 5oz flywheel)
4. 35.5 mm Mikuni flat slides on alcohol(done by ftz)with external power jets.
5. K&N clamp ons
6. C&O drag pipes
7. Billet clutch basket
8. +6 swingarm
9. Purple pearl with metalic painted plastic, bright yellow frame, cascade seat cover and cascade side cover inserts.
And probably some other stuff I forgot about!
Old Nov 9, 1999 | 02:12 PM
fooshead's Avatar
96 Banshee
1)Toomey T5 Pipes
2)Prodesign Pro Flow with K&N Filter
3)Dyno Jet Kit
4)Boyseen Carbon Fiber Dual Stage Reeds
5)Front & Rear ITP HOLE SHOTS on .190 douglas rims
6)GBC SAND DEVIL PADDLES on .190 douglas rims
Next Mod is sending motor off this winter to be built up (ported, crank welded, the usuall stuff)
<a href="http://www.spiff.net/~fooshead/frames9.htm">Foosheads Web Page</a>
Brian
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
JakeXBL
Sep 5, 2015 01:08 PM
