sp 500 rev limiter
Old Apr 29, 2007 | 06:22 PM
poptop's Avatar
Default sp 500 rev limiter
looking for help i have a 99 sp 500 it was running perfect then i went in reverse and i believe the rev limiter kicked in the problem is now no matter what it wont disengage when in high gear from idle the machine accelerates good but then it cuts out can i bypass the limiter to test it i hate to fork out 270 bucks for a new speedo if thats not the problem
Old Apr 29, 2007 | 10:07 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
guessing, but most likely it s the switch on the tranny that shows what gear its in in bad. help me out trail.
Old Apr 29, 2007 | 10:13 PM
poptop's Avatar
only thing is i hit the overide switch and it still cuts out might have to taker to polaris for this one
Old Apr 29, 2007 | 10:14 PM
trailbound's Avatar
That sounds like a good possibility. I'm trying to remember how the system on a 99 model works. I'll look at my book and try to get back with you. I think you can bypass the switch because quadovator sell a kit for it.
Old Apr 29, 2007 | 10:16 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
check the switch on the trans to make sure the connections are all good and maybe the contacts.
Old Apr 29, 2007 | 10:18 PM
poptop's Avatar
if i have it right there is a rev limiter built into the speedo i thought that would be the problem but a trans switch is surely much cheaper thanks for the help this is frustrating this machine is a money pit. lol
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
Sep 17, 2015 03:06 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
