what kind of oil?
Old Apr 29, 2007 | 09:43 PM
Sontizzle's Avatar
Default what kind of oil?
what kind of oil usually so u put in a 01 400ex?
Old Apr 29, 2007 | 10:10 PM
quicksilver's Avatar
reconranger will be in here soon to give you some advice.....
Old Apr 29, 2007 | 10:13 PM
Sontizzle's Avatar
i hope so soon, i jus got this thing thursday andi checked the oil tonight and its low but i dont kno what to put in it and im takin it on a 3 day campin trip tomorrow
Old Apr 29, 2007 | 11:52 PM
well, the 400ex shares the oil with the transmission and has a 'wet' type clutch, meaning the clutch is in the oil. So you need a "motorcycle" type oil, regular car oil is formulated for pistons and a crankshaft only, car engines do not contain a gear transmission or a clutch. Honda's GN-4 is a regular petroleum oil that will work well for this, Amsoil, Mobil 1 and better yet, Maxima makes high-quality synthetics for motorcycles as well, but the pricetag is higher (amsoil at the local auto parts store is about the same price as honda's GN4 at a dealer, it's a no-brainer..)
just make sure you use a motorcycle oil that has an API SG rating and also meets JASO MA certification (not MB) the MA certification means it's safe for use in an engine/transmission with a wet clutch. You could get by with car oil in a pinch (if you had a leak and the ONLY thing you had was car oil to get you home) obviously some oil is better than no oil at all, but avoid this if at all possible, and change it out asap if you do. 10w40 weight should be ok, consult a manual to be sure.
reconranger is usually quite prompt about posting replies to oil related questions, i hold his info in high regards. I think he's a biochemist too, so he knows his stuff.
Old Apr 30, 2007 | 12:02 AM
Sontizzle's Avatar
is there any kind of ATV oil i could pick up at a wal mart? im leavin early in the mornin on a trip and dont have time to go to a dealer.
Old Apr 30, 2007 | 01:45 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
See this post: http://forums.atvconnection.com/mess...did/518224.cfm
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Alex G.
Sep 16, 2015 12:13 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
