400ex rear axle movement
Old May 1, 2007 | 01:11 PM
stoney07's Avatar
Default 400ex rear axle movement
First post so bare with me. I have a '02 400ex that I just bought used about 1 month ago and the last time I rode the rear axle was moving from right to left about 1 1/2" in between the brake rotor and the chain sprocket. I did a search for this issue but didn't find any posts. The bearings do not make any noise and it rides normal. Can I fix this just by tightening the lock nut or do I need to replace the bearings? If anybody has had this issue any help would be greatly appreciated. thanks.
Old May 1, 2007 | 01:17 PM
hondabuster's Avatar
If it moved and moves that much, then crap got past the seals. You need to disassemble, the axle from the carrier, and clean and inspect it all, before just reclamping the lock nut. Its important to get all the water and dirt out of there, because if the carrier starts to wear out, it gets expensive to fix.
Old May 1, 2007 | 02:28 PM
slomoe's Avatar
IF THE AXLE IS MOVING THAT MUCH YOU NEED TO REPLACE THE BEARINGS & SEALS
Old May 1, 2007 | 02:32 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
See my comments here: http://forums.atvconnection.com/mess...did/518467.cfm
1986Vmax540
Jul 9, 2021 09:53 PM
STLyamwar
Jul 25, 2020 04:44 AM
bigred20653
Aug 31, 2015 12:41 PM
DeFox500
Aug 14, 2015 05:59 PM
Rider252
Jul 6, 2015 03:37 PM
