98 400 Scrambler Mods
Old May 2, 2007 | 10:18 AM
mtnxtreme800's Avatar
Default 98 400 Scrambler Mods
My 98 400 has a Hot Seat pipe and V Force reeds, it seems kinda doggy down bottom, no quick 2 stroke snap, but pulls real hard to the top, are there any tips, are they just like that, I'm thinkin of a Ritter Stage 1 with the flywheel mod, I'm sure that will wake it up, but can I do anything till then?
Old May 2, 2007 | 01:21 PM
Grizzler's Avatar
Do you have it clutched correctly for that pipe?
Old May 2, 2007 | 07:25 PM
ftwflh's Avatar
That pipe needs to have a brown or red/yelow primary spring,S55 or 10AL weights and ethir a HSP white,Aaen blue or HPD violet secondary spring. It needs a high engament to get things working.
Old May 2, 2007 | 07:34 PM
scramblered's Avatar
yes,the hot seat pipe is not real throttle happy down low but it snap real hard at top i known cuaze i've already ran them kit in the past,it like a tmx 38 or 42 at best,put some shim at the header's pipe to put more low end grunt,but it will decrease the peak hp a little.a flywheel lightening work real well with that pipe,helping to build rpm faster.
Old May 2, 2007 | 08:16 PM
I don't know what springs it has, but it seems to engage high, can I use those clutch setups if I do the flywheel lighteneing and porting etc, or do it together.
Old May 3, 2007 | 10:29 AM
yes,the hot seat pipe work best with a clutch to match along dialed-in properly,i would suggest to use hpd for the clutch parts,their helix are second to none,and the violet secondary spring is probably the best all around/race spring available for that quad,you can use hot seat weights.
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
