Spark Plug Question Please....
Old May 5, 2007 | 02:33 PM
Houdini64's Avatar
Default Spark Plug Question Please....
I am looking for some help on here I have just bought two Roketa RTX-250 atvs.... I have gone through them with a fine tooth comb and tighten every nut and bolt I have added UNI air filters on both of them and changed the oil first thing my question is I want to change the spark plug to NGK I have went to there site I have the LG D8TC in there now when I put that number in it came up with NGK DP8EA-9 but everyone I talked to told me just to use the NGK D8EA can someone tell what the difference is and what one should I run please the motor is a Zongshen any help would be thankfull.... P.S. is the gaps the same for the new NGK of .028
Old May 5, 2007 | 03:52 PM
SilveradoSS's Avatar
Went to the NGK website and looked up both plugs. The DP8EA-9 is a projected tip plug where the other is not. The ceramic insulator and the electrode stick out farther.
Go to the following links and compare the tips:
http://www.ngk.com/more_info.asp?AAIA=&pid=3297
http://www.ngk.com/more_info.asp?AAIA=&pid=3647
As to which one you need, I don't know. Not sure if there is a difference in the tip projection into the cylinder. There could be a clearance problem between the tip of the plug and the piston.
Old May 6, 2007 | 10:47 AM
LT80's Avatar
LT80 Expert
The protrusion is for lower rpm motors. Having the electrode further in the combustion chamber helps keep it clean. [img]i/expressions/face-icon-small-smile.gif[/img]
chammerbeck
Jul 17, 2015 08:06 AM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Unzzy66
Jul 11, 2015 10:01 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
D-Hagz
Jul 4, 2015 02:19 AM
