Baja 50cc Oil Change and Oil Level ?
Old May 7, 2007 | 10:38 AM
4yroldtrailburner's Avatar
Default Baja 50cc Oil Change and Oil Level ?
Picked up the Baja 50cc for my son who just turned four. He has been wearing it out. I had to make several adjustments after picking it up from Pep-Boys to get it dialed in. The manual stinks. I need to do the break in maintenece (oil change). There is no mention of proper oil level. When you unscrew the oil fill cap in the back, should I fill it all the way up? Thanks and now that it is broken in can/should I switch to synthetics, if so what weight/brand do you all recommend?
Old May 7, 2007 | 11:31 PM
2manytoys's Avatar
When you change the oil make sure you use a 4 stroke/motorcycle oil. 15w40 or 10w40. I tyake it your fill cap does not have a dip stick built into it? Is there a site glass on the right side of the motor?
Old May 8, 2007 | 07:40 AM
There is no dipstick on the cap and there is no site glass on the side of the motor. The manual says it hold approx 900ml. I can go by that on the oil change, but I was just curious as to how much I may need to put in there to make sure that it stays topped off.
Old May 8, 2007 | 09:06 AM
Timmerman's Avatar
J
Just wondering on how long it takes for brakein period. How many hours i wonder.
akguy31
Aug 31, 2019 04:34 AM
Jaymc
Sep 11, 2015 07:45 AM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
Jason Campbell
Sep 7, 2015 02:25 PM
Elkaholic
Sep 6, 2015 02:44 PM
