Moto 4 Cam Chain
Old May 7, 2007 | 10:11 PM
Bighomedog11's Avatar
Default Moto 4 Cam Chain
Hey guys, I want to remove my head on my ATV it is a Moto 4 1989 I think the older one. But i am wondering is it hard to Keep the cam chain right? because i want to remove my head to see if everything is fine in there. And I am also wondering when i remove it will i have to change the piston rings? Because the bike is very old been sitting outside and i want to get her back running
Old May 8, 2007 | 10:57 AM
ctateusa1's Avatar
you need to get a copy of the timing marks, because invariably it will move a little on you either way. removing the head is fairly simple to do though. what size is your moto 4?
As far as the rings, they are cheap but if you are that far into the bike, you should probably replace the rings, piston and have the cylinder machined to the next available size piston and replace the cam chain as well.
I just rebuilt the engine on a 87 moto 4 80cc and it cost me less than 200.00 for the cam chain, .25 over piston and rings, intake valve, headgasket and cylinder base gasket, as well as the labor to replace the intake valve and reseat them in the head, and the overbore on the cylinder.
Old May 8, 2007 | 04:09 PM
Ok yes its a 80cc Moto 4. So when i take off the Cam Chain lid what do i need to mark? Because i want to take off my head to see inside of it. like were do i suppose to mark at on my Cam Chain?
Old May 8, 2007 | 04:40 PM
ctateusa1's Avatar
well do not count on marking the cam chain because you will invariably get it out of time anyway I will try to upload a pic of the timing marks and how to do it
Old May 8, 2007 | 04:56 PM
ctateusa1's Avatar
If you want to pm your email address I will email you a service manual excerpt for a valve adjustment which also shows the timing marks on it to make sure that you have everything lined up right.
Old May 8, 2007 | 10:51 PM
Ok i will! My Email is Bighomedog11@gmail.com
Old Sep 4, 2007 | 07:30 PM
lexzack's Avatar
Hey could you please send me a copy of the service manual excerpt for a valve adjustment which also shows the timing marks on it to I need to time mine that i just had apart and didnt get it baack right?
Thanks in advance
tinarhuffman@mikrotec.com
Old Sep 4, 2007 | 08:12 PM
ctateusa1's Avatar
What size moto 4?
Old Sep 5, 2007 | 12:40 AM
lexzack's Avatar
Its a moto 4 80 like a 1986
Old Sep 5, 2007 | 08:49 AM
ctateusa1's Avatar
alright let me see if I can dig up my scan of the timing again and I will send it to you today. mine is an 87 so it should be about the same.
