Swing arm is loose
Old May 7, 2007 | 10:27 PM
sbishop664's Avatar
Default Swing arm is loose
Hi, I have about 1/4" to 1/2" play in my swing arm from left to right. should the bushings be replace or try tighting up the nuts on both side? how do I access the nut on the left side? remove the clutch?
Thanks for any help!
96 Xplorer 400
Sbishop
Old May 8, 2007 | 02:09 AM
Kerbmonster's Avatar
i'd say the bushings need replaced, and if u haven't yet, since ur there, maybe your chains and sprockets, save ya some time
Old May 8, 2007 | 06:00 AM
sbishop664's Avatar
Anyone changed these before? any suggestions on how to tackle it?
Thanks
Sbishop
Old May 8, 2007 | 06:26 PM
drlang's Avatar
Look for the chain side swing arm bolt moving forward and back in the frame. Common problem on those. I just rebuilt my 250, then the front end gave out. Kind of a waste of money for me. Doc
Old May 8, 2007 | 11:13 PM
sbishop664's Avatar
I took apart the chain side....bolt was loose...I tighten it at least 1 and half turns...my swing arm is tight now
I put back the old bearings to see how things are and my sprocket hub is rubbing against the hitch where the chain had made a groove...and i'm to grind down the groove flush and pick up new bearings tomorrow.
I still have some play on the rear axle..so i'm thinking the new bearings will help with that!
thanks for the reply guys
Sbishop
MeadowlarkFarm
Nov 27, 2019 08:40 PM
fd24
Jan 16, 2019 08:59 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
jankerstien
Sep 21, 2015 03:09 AM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
